Old 09-15-2019, 03:38 AM
GRAFFZ GRAFFZ is offline
Default 1966-1967 Chevelle NOS GM AM Radio/Speaker/Bezel, Hood Ground, Pulley, + Regulator
NOS GM Push Button AM radio assembly. By the part# it is 100% correct for 1967 model year, but will work for the 1966 as well. You would be hard pressed to find a nicer one. MINT NOS condition.
*******SOLD*******
NOS GM radio dash speaker assembly. Brand New and never bolted up. MINT NOS condition.
*******SOLD*******
NOS GM radio dash bezel. Correct for 1967 model year only. You will be hard pressed to find a nicer one. The GM part# is embossed on the back side. MINT NOS condition.
*******SOLD*******
NOS GM Radio hood ground. It mounts at the right side of the cowl panel using the far RH screw hole for mounting. It grounds the hood when closed to prevent static in your radio.
*******SOLD*******
NOS GM Delco 1119515 voltage regulator. Date coded 6H(August, 1966).
*******SOLD*******
NOS GM Alternator fan with pulley. Made by GM back in 11/1968. The GM part# is stamped on the pulley itself.
*******SOLD*******
Thanks, Sam
Attachments - The Supercar Registry 986853#1C.jpg 986853#1A.jpg 7293691#1B.jpg 7293691#1A.jpg
