Old 09-03-2019, 08:11 PM
prospersupercars prospersupercars is offline
Default 1972 Chevrolet Nova, 5.3 LS, 4L60e
100% reliable car that was professionally built with ZERO corners cut. Car gets 22-25mpg and has around 3500 miles on the build. Have all the receipts for the build. You can literally fly in and drive this one home. Asking $38K
•04 Aluminum 5.3 with 60K miles
•Replaced all gaskets/seals before install
•Texas Speed 224 Camshaft/matched springs/push rods
•New HV Oil Pump & New Timing Chain
•Holley Swap Oil Pan
•Holley Intake, Fuel Rails, Throttle Body
•GM ECM/Custom Wiring Harness with Professional Dyno Tune - 324hp and 302tq at the rear wheels
•Hooker Headers
•New Dual 3" Stainless Magnaflow Exhaust System
•NEW GM Reman 4L60e Transmission with 2500 stall convertor
•8.5 10 bolt with new Eaton Posi and 3.73 Gears
•Front Disc Brake Conversion/New Rear Drum Brakes
•Full 3" lowered Hotchkis Suspension with Tuned Fox Shocks
•Hotchkis Subframe Connectors
•Custom 17" Circle Racing Billet Aluminum Wheels with New Falken tires 245/45/17 front and 275/40/17 rear
•Speedometer Conversion to run factory cable driven speedo
•Interior is spotless with OG rubber mat and door panels. New OE seat covers.
•New Starter/Alternator/Power Steering Pump/Water Pump
•Original Radiator Re-Cored with HD 3 Row Core
•Custom Fan Shroud and HP Electric Cooling Fan
•Original Owners Manual and Protecto-Plate
•Original Paint - Solid Car
The Following 7 Users Say Thank You to prospersupercars For This Useful Post:
72heavychevy (09-04-2019), Billohio (09-04-2019), dykstra (09-06-2019), John (09-04-2019), markinnaples (09-03-2019), PeteLeathersac (09-13-2019), Tommy (09-03-2019)
Attachments - The Supercar Registry Zach Carter 72 Nova 7 (1280x853) (1024x682).jpg IMG_E3837 (1024x568).jpg IMG_E3836 (1280x720).jpg IMG_E3833 (1280x650).jpg
