Old 08-01-2019, 02:20 AM
Spooky's Avatar
Spooky Spooky is offline
Default 60's vintage scattershield/ Bell housing also block plate
I traded with the original owner of this Lakewood Bell housing, I just removed the cheap paint he had on it. Original owner swears it did not come painted from new! Only had one trans attached to it. All bolt holes are perfect. Factory truing/ grinding present, Never had any sanding, blasting, welding or anything else funky. Still has 5 out of 6 original LE bolts that are for the bottom inspection plate. There is no part number stamped on it, it is so early. A dip in evaporust would truly make this amazing!
$375 + actual shipping
Paypal F&F preferred
Thanks SYC!
Scott
69 Camaro RS/SS X22 4speed NOM but working on something special
69 Camaro x11 355 crossram m22 12 bolt 3.73's
