Old 07-28-2019, 01:53 PM
dlv4540 dlv4540 is offline
Default 1970 396-375HP L78 Engine #3969854
1970 396 block .030 with casting number 3969854 dated H-20-9 and has the CKO code on the front pad with a willow run nova vin. The block was cleaned, magged and pressure tested and fitted with two sleeves due to small crack in cylinders #5 & #7. Block comes with the original 3964291 square port heads dated F-6-9 and F-18-9 cleaned and magged with a set of hardware to rebuild. Block also comes with the 11 to 1 pistons and rods with 6 original and two newer ones. 6223 steel crank turned .010 under will need polished. I also have the correct 8 inch harmonic balancer to go with it and can ship if you cannot pick up. $3250 for the whole engine and will include free shipping in the USA. Canada I can ship to but will need to work something out on the shipping.
330-770-2517 for any questions.
Dennis Vugrinovich
