Old 07-23-2019, 10:40 PM
Enoch Enoch is offline
Banned
Default Assembly line Weatherhead petcock radiator drain
Very nice original assembly line installed Weatherhead petcock with original Weatherhead logos on the underside and 94 stamp. Originals are very hard to find. $60 ppff
Old 07-23-2019, 11:00 PM
XXXGoldL34M20's Avatar
Rich from my experience with 1970 Chevelle Big blocks (can't speak for other models)
The assembly line Petcocks I have seen have also had the Weatherhead or Eaton Logo right on one side of the bolt and the bottom had a unique flat head notch.
See photos.
What you have IMO is an over the counter unit if it does not have a logo on one bolt side.
The Following User Says Thank You to XXXGoldL34M20 For This Useful Post:
Enoch (07-23-2019)
Old 07-24-2019, 12:03 AM
Banned
Danny, thanks as always good info :-)
Here's some of the observations of some of the other original petcocks I have and the different configurations they came in.
1 brass tube no logo on underside of arms. Weatherhead stamped on flat,
2 steel tube no logo on underside of arms. Weatherhead logo on flat
3 no tube 94 + <w> stamped on arms (which is installed flats away from radiator
4 steel tube 94 <w> stamped on arms. Weatherhead stamped on flat
I have also seen 1, 2 and 4 on late 60's early 70's.
Old 07-24-2019, 12:23 AM
Banned
Thumbs down
Here's a picture of some original of what I believe are assembly line eaton petcocks. They don't have stamping on the brass but they have the ridge on the underside of the arms. Most hexes have a line a vertical line or two running up and down from the stamping process.
Old 07-24-2019, 12:46 AM
Banned
Two more original Weatherhead petcocks. One with brass tube one with steel tube. $60 each ppff
Old 07-24-2019, 02:27 AM
Assembly Line Eaton Petcocks both from a 1970 Chevelle SS Big block,
Like I mentioned below that I can only reflect on 1970 Chevelle's don't know or study any other models.
Old 07-27-2019, 01:34 PM
Banned
New prices $45 each
Old 08-08-2019, 05:45 PM
Banned
$35 each
