Old 07-22-2019, 01:06 AM
RALLY RALLY is online now
Default 72 Nova SS- engine will not shut off?
I took my Nova for a ride. Car started great but after parking my car in the garage and turning off the ignition switch to off the car kept running. I then moving the switch to the start position and off back and forth a few times and engine still would not shut off. Does this sound like a bad ignition switch that is mounted on the lower steering column towards the floorboard? I know the switch up top has a rod that operates this ignition switch below. Does it sound like a bad switch? I did pull the ground on the battery after i stalled the engine to shut off and move the switch to the off and on positions about 5 times. Hooked up the ground on the battery and the car started and then shut off. Any input please? Thank you.
Old 07-22-2019, 01:07 AM
Spooky's Avatar
Spooky Spooky is offline
Does it have a MSD Box?
69 Camaro RS/SS X22 4speed NOM but working on something special
69 Camaro x11 355 crossram m22 12 bolt 3.73's
Old 07-22-2019, 01:31 AM
No MSD box, use to have one. I removed the box.
Old 07-22-2019, 02:33 AM
Talked to a good mechanic who told me to check and see if the Alternator is causing the run on problem with ignition in the off position and engine still running. Its a simple test to do. Will check this week.
