Old 07-20-2019, 02:48 PM
dmarr35 dmarr35 is offline
Default 1969 427 timing chain distributor question
I am replacing the cam on a 1969 427 the question I have is after lining up the gears at 6 oclock cam and 12 oclock crank I bring the cam gear to 12 oclock that puts the number 1 cylinder at compression when I install my distributor do I set it at pointing at 1 or do I set gears at 6 and 12 and set pointing to 1? Thank You for the advice
Old 07-20-2019, 05:42 PM
bbbentley's Avatar
Should be one complete revolution of the crank, which would put the crank dot back @ 12:00 and cam gear dot at 12:00. Both rocker arms on the #1 lh front ( referenced from sitting in drivers seat), should be in the up ( valves closed ) position. Distributor pointing to # 1
Like you said, the compression stroke
FULL OWNER HISTORY
Old 07-21-2019, 01:39 AM
1971ls6's Avatar
1971ls6 1971ls6 is offline
#1 on the cap, not physically the front left #1 cylinder
1969 ZL1 COPO Camaro 11.60@120 F.A.S.T 21
1971 LS6 vette 12.20 @118 PSMCDR
Old 07-21-2019, 03:59 AM
Plowman's Avatar
Plowman Plowman is offline
Yes that is good or first post put it in on#6 on cap too. The two dots together drop in #6 cap too,if that helps.
Old 07-21-2019, 11:54 PM
Yes Thank You
Old 07-22-2019, 12:52 PM
earntaz earntaz is offline
yup -- the infamous "180 out" ...
