Old 06-29-2019, 02:54 AM
1stgen 1stgen is offline
Default 1968 Camaro Black Beauty runs low 11’s
Located in Cherry hill, Nj
$25k obo or Willing to trade for stock muscle car of equal value or trade down if the money is right (preferably 4 spd)
-built for the strip, but could be brought back for the street
-clear nj title
-steel body
-383 stroker
-runs low 11’s on pump gas
-11’s on pump gas naturally aspirated with NO NOS
-have entire jegs “bible” on what’s in this beast and the history of passes made
-inner rear wells only stretched and not tubbed
-cage built to run thru dash vents in order to not hack the camaro up.
-solid body car and undercarriage
-Beautiful thick black paint
-have 68 buckets if someone wants to remove cage and take back to street
Some equip:
MSD Ignition
Holley 750 hp carb
Intake jr Edelbrock
Jegs alumin heads
Balance & print short block 383kit
Fluid damper balance
Morso deep oil pan
Trans 350 turbo maual valve
Ati converter 5000 stall
Hurst quarter stick shifter and line lock
Safety loop for drive shaft and frame connectors
Rear gm 12bolt posi
456 gears with strange axles and spool and traction bars j bolt style
Here's a link to over 100 photos of the Camaro:
http://s1352.photobucket.com/user/Ch...%2068%20Camaro
