Old 06-23-2019, 08:18 PM
WorkinProgress WorkinProgress is offline
Default Mystery Part
Can anyone I.D. this shield? Part is 10" long X 7 1/2" wide.
Thanks, Warren
Old 06-23-2019, 09:24 PM
chevelleshack chevelleshack is offline
Transmission linkage shield on a 70 gto . That's the last place i saw one of those . Mounts to the bellhousing of an automatic transmission . Sound right ?
The Following User Says Thank You to chevelleshack For This Useful Post:
WorkinProgress (06-24-2019)
Old 06-24-2019, 09:27 PM
I found this part in an original L78 '69 Camaro that was being transformed into a drag car. I bought the car in '88 and the car had been sitting in a garage since '72 in Jamaica Queens, New York.
Originally I thought it might be a starter shield but quickly found out it wasn't.
chevelleshack, thanks for hopefully pointing me in the right direction. I will do some more research on the info you provided.
- Warren
Old 06-25-2019, 03:10 AM
https://www.restorationperformance.c...YaAs9YEALw_wcB
The Following 2 Users Say Thank You to Charley Lillard For This Useful Post:
fsc66 (06-25-2019), WorkinProgress (06-25-2019)
Old 06-25-2019, 03:11 AM
Old 06-25-2019, 01:05 PM
That pic is for a 4 speed . Bolts to the inspection shield holes of an automatic trans bellhousing .
Old 06-25-2019, 05:44 PM
So, I can assume the part only fits automatic with column shift and not including automatic with floor shift?
- Warren
Old 06-25-2019, 11:17 PM
No , this was on a floor shift car . Would not matter though , still has the back drive linkage for key / shifter lock .
WorkinProgress (06-26-2019)
