Old 06-11-2019, 04:51 PM
chris slawski chris slawski is offline
Default 69 Camaro tetanus booster included
69 camaro complete car with clear title in my name in my hand
$7500.00
no not 75 dollars, and not 750 dollars...7 thousand 5 hundred dollars.
6 cylinder
Automatic trans
Originally black standard interior, still is, paint code is -B which is "special color and black vinyl top" original color under top appears to be butternut yellow.
Drum breaks
Does NOT run.
Rolls really nice. Broken tie rod sleeve so 1 wheel needs assistance steering. New sleeve included.
Complete car less headlights and fuel line pump to carb. All those little parts that are missing on the 10k shell are included.
Yes it has rust.
Clear title in my hand in my name.
New rad support, new NOS grill, and grill stiffener. Rally wheels go with the car.
No trades. No shipping. No opinions.
Location: I am in Medford Lakes NJ about 20 miles straight east from Philadelphia
How are the rockers: the rockers are solid.
How are the quarters: they need at least skins, and outer wheel houses and drop offs.
How is the rear window area: if needs the filler panel between the rear window and trunk.
How is the subframe: it is straight but need repair where the body bushings go (like they all do)
How is the glass: all glass is intact, no cracks, but it is fogged over.
How are the floors: as I said the car is RUSTY. The driver foot well, and passenger rear foot well can both be patched, or you can go crazy and do a full floor (I would just patch and drive since not a super valuable model)
How is the trunk.: I cannot honestly say because I cannot get the trunk to unlock, the dent in the rear tail panel put a bend in the lock rod and the lock will not turn. I am assuming it will need some work.
How are the rear frame frames: the passenger rear frame rail, all the way at the back needs repair, you can get a partial rear frame rail and that would fix it. The leaf springs are not thru the floor so they are overall solid.
Do you have any other pictures: yes I have one picture where I have the hood off, and the rad support components removed as I was going to replace the rad support panel, and I was tired of hitting my head on the hood. All the removed components Including, hood latch, hood lock, hood latch support, and rad support bars, hood and hood hinges are all included in the sale. The hardware too. I can do a quick reassemble so all is there for transport.
Some of the trim was not with the car when I purchased. They have been sourced and are included in the sale.
It is all the little stuff that adds up.
I try to be as honest as possible, as I do not want someone to make the drive, how ever long it may be and not know what to expect.
the gold car is for inspiration.
Last edited by chris slawski; 06-11-2019 at 04:58 PM. Reason: forgot to list price
Attachments - The Supercar Registry old sock gets old shoes.jpg lamy.jpg clifford passenger side.jpg clifford driver rear.jpg
