Old 06-01-2019, 06:06 PM
Enoch Enoch is offline
Banned
Default 12 bolt 10 bolt and Corvette rear end hardware
I have a lot of rear end cover and guts hardware for all of the above mentioned.
1. starting from the front left is a set of 12 bolt ring gear CH head marking bolts (also correct for corvette and 10 bolt. $40
2. a set of o head marking 12 bolt ring gear mounting bolts (also correct for corvette and 10 bolt) $40
3. and the back row has four [] and 4 M carrier bearing mounting bolts. (Also correct for corvette and 10 bolt) $40 per set of 4
4. Finally to the right in the back row is the gear pin bolt. Four different head markings.
N1L4
WB
(F)
L8
$15 each
I will continue listing hardware for the rear ends so keep checking back. Head if there's anything specific your looking for just ask I most likely will have it.
Attachments - The Supercar Registry 20190601_134628-1008x567.jpg 20190601_133833-1008x567.jpg 20190601_133436-1008x567.jpg 20190601_133436-1008x567.jpg
Old 06-01-2019, 06:42 PM
Banned
Very nice set of RBW head marking 12 bolt cover to rear end mounting bolts and one L head marking brake line bracket to rear mounting bolt. Very nice very hard head marking to find. SOLD $65 SOLD
Old 06-01-2019, 06:52 PM
Banned
Very nice set of n head marking 12 bolt rear end cover mounting bolts and flying F head marking rear brake line mounting bolt. SOLD $60 SOLD
Old 06-01-2019, 10:16 PM
mr1969chevelless mr1969chevelless is offline
ill message you
The Following User Says Thank You to mr1969chevelless For This Useful Post:
Enoch (06-01-2019)
Old 06-01-2019, 11:23 PM
Banned
Okay the 12 bolt cover bolts sold out really fast and I had some private message requests for more. I'll definitely put some more sets together and list them here later.
