Old 05-20-2019, 01:27 PM
madden madden is offline
Default LT1 return spring attachment?
hi
need a bit of help
wondering how the return spring is attached for 1970 4555 carb on a 4spd car.
i understand that at the back it goes thru the hole in the throttle bracket but where does it go at the front?
any help and pictures would be helpful
please send info to this e-mail
[email protected]
thanks
chris
1970 citrus Yenko Nova
Old 05-20-2019, 01:49 PM
Email sent. From a Camaro but believe they are in the same location. Hope it helps.
madden (05-20-2019)
Old 05-20-2019, 02:42 PM
70 Forest Green Zee's Avatar
70 Forest Green Zee 70 Forest Green Zee is offline
This is from a 1970 Z28 4489 Holley. The 4489 was specific to NA9 Calif emissions but I'm pretty sure the return spring connects the same as non Calif emissions carbs. Hope this helps.
1970Camaro Z28
The Following User Says Thank You to 70 Forest Green Zee For This Useful Post:
madden (05-20-2019)
Old 05-20-2019, 05:33 PM
GrumpyJeff's Avatar
Yep, mines exactly like this also
The Following User Says Thank You to GrumpyJeff For This Useful Post:
madden (05-20-2019)
