Old 05-12-2019, 04:03 PM
madden madden is offline
Default Bbc fuel pump identification
hi
need help ID. this fuel pump
i have a box full of these.............i believe they are bbc AC delco mechanical fuel pumps
some have ac on the bottom and others dont
got them from a gm dealership and was told they were 396/427 hp ????
any help with ID and valve of what they are worth would be great
thanks so very much
regards
chris
1970 citrus Yenko Nova
Attachments - The Supercar Registry BBC FUEL PUMP 3.jpg BBC FUEL PUMP 2.jpg BBC FUEL PUMP 1.jpg
Old 05-12-2019, 04:05 PM
John Brown's Avatar
Any numbers stamped on the edge of the mounting flanges?
John Brown
Old 05-12-2019, 05:58 PM
mssl72's Avatar
mssl72 mssl72 is offline
I have a similar fuel pump, outlet and inlet are positioned different than yours. Mine has a small aluminum tag attached under the head of one of the screws on the main body. It has a part number and another number that looks like a build date stamped on it. It looks like your tag may have been lost.
Mark
1966 L72, 4spd Caprice
1974 Z28, M40 Camaro
Old 05-12-2019, 08:24 PM
1971ls6's Avatar
1971ls6 1971ls6 is offline
What size thread are on the in and out
1969 ZL1 COPO Camaro 11.60@120 F.A.S.T 21
1971 LS6 vette 12.20 @118 PSMCDR
Old 05-13-2019, 01:01 PM
no stamped numbers on flanges
inlet and out let are both 1/4 NPT thread on them
i also have a few nos pumps with the 4 screws in the bottom and look identical to the bbc fuel pump on ebay presentlly for sale.... item number below
eBay item number:133037425107
that is what is making think they are assemble line bbc hi-perf fuel pumps
thx
chris
Old 05-14-2019, 01:19 PM
Flying Undertaker Flying Undertaker is offline
AC made rebuildable fuel pumps like the one pictured for small block & big block Chevrolets. GM part # 6415325 is for the Corvette HP small block & # 6415748 was for the Corvette big block. These fuel pumps were recommended by Chevrolet for racing usage back in the day. I believe the only difference was the fuel pump arm (lever). Big Blocks were usually stamped either 40170 or 40731, Small Blocks had the metal tag with the stamped number. Small Blocks had the cast aluminum bottom cover as shown, Big Blocks had either the cast cover but more often had the stamped steel gold iridite cover. Don.
Old 05-14-2019, 03:30 PM
big gear head's Avatar
Looks like they may have been made by Carter.
Freddie
Old 05-14-2019, 09:22 PM
hiperf69 hiperf69 is offline
Yenko Advertising Member
I’m thinking this is a low HP pump.
As I remember, all the High HP pumps stick out away from the block
by 3/4” or more like on the 40394 L-79 ChevyII Pumps
1965 L-79 was the same way.
A completely different top casting.
All HP pumps use the stamped steel bottom plate I believe.
Joe
Old 05-14-2019, 10:26 PM
MarcDant's Avatar
MarcDant MarcDant is offline
Looks a lot like a 409 hp pump.
Old 05-15-2019, 01:25 AM
1971ls6's Avatar
Big block high hp pumps used 3/8 lines
