Old 04-07-2019, 08:23 PM
Spooky's Avatar
Spooky Spooky is offline
Default fan/Eaton clutch ID and wiw
Just pulled a unstamped fan (Hayes-Albion) out of my brothers shop. It has a bad rattle can spray job on it but looks strait and has a 69 style Eaton clutch on it. Looks like it might be a short shaft big block version (not sure). I don't want to clean it up too much in case there are stampings underneath the paint. what should I be looking for? There are no dates on the shaft or hub or any "this side up" markings. Thanks for any help!
Scott
69 Camaro RS/SS X22 4speed NOM but working on something special
69 Camaro x11 355 crossram m22 12 bolt 3.73's
Old 04-08-2019, 02:26 AM
L78 Fred L78 Fred is offline
I can send you picts and measurements
text me 610-585-4155
I would be interested if it is a short shaft
thank you
Fred
Fred
[email protected]
610-585-4155
WANTED:
Old 04-09-2019, 01:06 AM
Spooky's Avatar
Thanks for the offer Fred!
I got directed to the cooling chart at CRG. It had some good info on what the stampings are and where they are located.
I took a chance and gently removed some paint with my fingernail. Not expecting to find anything, I was totally shocked to see the original ink stamps.
Looks like an assembly line 396/375 or 427/425 fan and clutch by the info at CRG. Sound correct?
Scott
Old 04-09-2019, 02:05 AM
Should be 1970 396/375 HP
1969 was J
Let me know if you want to sell it and how much
Thank you
Fred
Fred
[email protected]
610-585-4155
WANTED:
Old 04-09-2019, 02:10 AM
Spooky's Avatar
If J was 69, than I would be 68?
K would be month (October) 28 day of I 1968 is the way I read it on CRG. I may be wrong though. Experts please chime in.
Scott
Old 04-09-2019, 12:09 PM
Rixls6 Rixls6 is offline
That clutch, if correct date is Oct. of 68, would be perfect for my October built 69 Post sedan SS396.
Rick
Don't text and drive.
Old 04-09-2019, 01:24 PM
John Brown's Avatar
Scott
If I was 68 and J was 69, it follows that K would most likely be 70.
John Brown
Old 04-09-2019, 10:58 PM
Spooky's Avatar
Actually the info I read was here at Yenko.net
https://www.yenko.net/forum/showthre...eaton+tutorial
Scott
Old 04-10-2019, 01:55 AM
Spooky,
Thank you for reposting this- My mistake going from memory regarding the order of the date code
I- 68
J-69
Fred
Fred
[email protected]
610-585-4155
WANTED:
