Old 03-10-2019, 11:50 PM
Enoch Enoch is offline
Banned
Default Full Concours restored original front end suspension Hardware kits
All hardware are factory original assembly line installed pieces. No aftermarket pieces. All period correct head markings and finishes. Kits will be made specific to year and body.
The following is a breakdown of applications in a typical kit:
1. Front sway bar bushings retainer to frame bolts
2. Lower a arm mounting bolt
3. Upper a arm bushing retainer bolts
4. Upper a arm to frame studs and nuts
5. Steering box mounting bolts
6. Idler arm mounting bolts
7. Front shock mounting bolts and nuts
8. Back drive and cross shaft to frame mounting bolts
9. Sway bar bushing end play clamp mounting bolts
10. Tie rod end clamp bolts and nuts
All hardware is restored to concourse level quality. We start out with original pieces which are chemically cleaned to prep for the plating process . Each is then visually inspected to insure there is no pitting, rounded corners or stripped threads. Any pieces that don't meet these standards are discarded. From there each piece is plated as called for per factory specifications.
Kits are $375 plus $15 to fully insure and ship to the lower 48 via Pay pal friends and family.
Kits will be made for specific applications such as:
67-69 F-body Camaro/Firebird
68-72 Nova
65-69 A-body Chevelle GTO 442
70-72 F-body Camaro/Firebird
70-72 A-body Chevelle GTO 442
Kits will also be made for other applications upon request.
Keep watching this thread as it will be updated with new kits regularly.
Attachments - The Supercar Registry 20190310_194213-567x1008.jpg 20190310_194138-1008x567.jpg 20190310_193934-1008x567.jpg 20190310_193128-1008x567.jpg
