Old 01-05-2019, 01:00 AM
madden madden is offline
Default Help...deuce master/ booster disassembly
hi
need help guys
cleaning/ restoring my 1970 deuce brake booster set up
-removed the brake vacuum booster...no issues
-removed the master brake cylinder.....no issues
-removed the small top support bracket (one with the 1 mounting hole in it)....no issues
-but the large long mounting bracket (one with the 2 mounting holes in it) shown in the first picture.........i just can not figure out how that piece is removed/ separated from the brake line assemble
anyone done this.........if so what gives
some help would be GREATLY appreciated guys....pics if you have them as to how this get disassembled
thanks so very much
regards
chris
1970 citrus Yenko Nova
Attachments - The Supercar Registry DSCN2124 revised.jpg DSCN2117 revised.jpg
Old 01-05-2019, 02:20 AM
70post 70post is offline
Haven't messed with any of that model but there's a good chance that it has some tabs on it somewhere that were "pinched" onto a corresponding raised spot on the "valve body".
Get an inspection mirror and see if it's attached to the underside of the block/body...can't see the whole piece in your pics.
EDIT AND ADD: Looking at your first pic....does that bracket run all the way up to the area where the steel brake line/fitting is attached to the "valve body"???
Patton Glade
70Post Restorations
Austin, TX
Old 01-05-2019, 05:58 PM
z28s4mjg z28s4mjg is offline
Don't know how to post pictures but if you send a phone number or email address I will get you some pictures of parts removed from 70 Z28.
Mike
Old 01-05-2019, 08:22 PM
Spooky's Avatar
Spooky Spooky is offline
Chris, Does your car have big block frame stands? Looks like it in the pics.
Scott
69 Camaro RS/SS X22 4speed NOM but working on something special
69 Camaro x11 355 crossram m22 12 bolt 3.73's
