Old 12-16-2018, 10:12 PM
Burd's Avatar
Burd Burd is offline
Default Freedom Battery Toppers
A small run of Freedom battery toppers were made, they are $75 plus $15 priority ship, insured, F/F PayPal if used please,
1976-1987 approx, I can narrow it down a bit with info from your build sheet. ( box 47) The eye is a 2- pc plexi, clear on top, Green under the clear, they look great, blue toppers are molded in blue, black are blue painted black, with a current interstate battery, which have the white case, (these toppers fit a 78 series battery) these give you the missing factory detail for your car.
These can be used on smaller battery’s, there will be a slight get overhang depending on size.
Inside dimensions, L-10 1/2, W-7 1/4 if your car doesn’t have a top hold down, small PCs of double sided tape can be use to hold the topper down.
It's only Orig once
waste all the rest.
1978 Y88
1995 Q45
The Following 2 Users Say Thank You to Burd For This Useful Post:
ScottG (02-13-2019), Steve Shauger (12-17-2018)
Attachments - The Supercar Registry B6FB7E41-5E0D-4DD4-8658-8D3A8CB36171.jpeg B37FDAB3-14E2-4BD9-9E65-462C494156E5.jpeg 9BC56830-08F8-43D5-B678-4B5AE2957881.jpeg 2D056828-859B-4BB9-981E-6731217C2B09.jpeg
