Old 11-29-2018, 04:15 AM
Default Industrial strenght carb cleaner
Loooooong story short. Chem Dip didn't cut it.
I need a really good carb cleaner. Not a spray can. Something I can soak carb parts in. I don't care if it takes off the gold finish. The carbs I am working on are plugged up somewhere, and I don't even know where. It isn't obvious to the naked eye with the carbs completely disassembled, and all jets etc, removed.
This is on my 69 Opel GT 1.1 with dual Solex carbs. I know something is plugged. I have a second set of carbs off of a 1.1 Kadette. I just rebuilt them and installed, and the car runs fine.
A little history. The car ran great in October. Sherri and I took it on an 80 mile round trip one Sat. Got over 40 mpg, and ran perfect. Sat for two weeks right after that trip. Started it up... ran for 3 to 5 seconds and quit. Again, I will spare you the novel, but the bottom line is my spare carbs are now installed and it runs fine. I would like to fix the original carbs.
Soaked all the pieces in Berryman's Chem Dip. Obviously did not clear the clog. I can start swapping parts (tops, bodies, baseplates) to see which part is clogged, but I will still need something to soak the offending parts in to fix the problem.
I have seen some posts on Pine Sol. Anyone try that?
Thanks for any help.
