Old 11-11-2018, 09:27 PM
dlv4540 dlv4540 is offline
Default 1968 427-435HP Tri Power Engine Rebuilt
I have a 427 4 bolt engine .030 rebuilt to stock specs with the 11 to 1 pistons, steel crankshaft and solid camshaft. Engine casting number 3916321 dated K-7-7 with no numbers on the front pad. Engine has the correct 3919852 tri power aluminum intake with a set of new holley 3659's and 4055 center carbs with linkage. Heads are 3964291 dated D-30-0 & E-07-0 and the engine comes with a 1111060 distributor dated 7F21, alternator 1102479 dated 7J28, motor mounts, original air cleaner, new ac plug wires and spark plugs, 6 quart oil pan and has a aftermarket replacement water pump and high volume fuel pump. Can ship if you cannot pick up $9500. Can provide pictures with a email address or phone number. Any questions I can be reached at 330-770-2517.
Dennis Vugrinovich
Old 11-22-2018, 03:58 PM
bump
Dennis Vugrinovich
