Old 10-18-2018, 03:38 PM
Default Clutch adjustment
Everything is new; flywheel, clutch, pressure plate, t/o bearing, clutch fork, z bar and adjustment rod. Car has zero miles on it, and yet with full adjustment the clutch only grabs at the very high end of the pedal. What did I do wrong this time....????
Old 10-18-2018, 03:39 PM
mockingbird812's Avatar
Is the engagement rod original?
edit: oops, i see you are saying that the "adjustment rod" is new. How does this adjustment rod compare to an original one? I can measure mine tonight.
Sam...
Old 10-18-2018, 04:06 PM
Igosplut's Avatar
Igosplut Igosplut is offline
Wait till after it breaks in, that will probably change.
WOT
The Following User Says Thank You to Igosplut For This Useful Post:
YENKO DEUCE REGISTRY (10-18-2018)
Old 10-18-2018, 05:24 PM
earntaz earntaz is offline
This may not apply, but here goes. Back in the day there were basically two TO bearings used. A short and a tall. If the diaphragm PP was flat when bolted down, the tall TO was used. If the diaphragm was extended out, the short TO was used. Just sayin' ... TAZ
The Following User Says Thank You to earntaz For This Useful Post:
Old 10-18-2018, 05:39 PM
Anyone got a pic of a BB vs SB adjustment rod for a Nova?
Old 10-18-2018, 05:46 PM
John Brown's Avatar
There is also a medium length t.o. bearing normally used on Pontiac applications. I will find those three numbers in a few.
John Brown
Old 10-18-2018, 06:02 PM
John Brown's Avatar
Ok, these are BCA numbers so you may have to interchange them.
Long = 1697C
Short = CC1705C
Medium = 1377C
You be the judge which one will be best for your application. Best to look at them in person and not just look at pictures of them on the net.
John Brown
Old 10-19-2018, 06:06 PM
Thanks all,
Old 10-20-2018, 02:41 AM
cwc's Avatar
cwc cwc is offline
If your clutch grabs high off the floor,then you need to shorten your adjustment rod,is that the direction you are going? How much free travel do you have?
1967 SS427 4 speed triple black survivor-sold to a good home
1969 nova SS396 L78 4 speed triple black survivor
1970 camaro SS350 citrus green,Dad bought it new!
1968 chevelle ss396 L34 M21 KK rear all born with
1972 formula 400 M22
The Following User Says Thank You to cwc For This Useful Post:
YENKO DEUCE REGISTRY (10-22-2018)
Old 10-20-2018, 03:42 AM
ssl78 ssl78 is offline
Is the rubber pedal stop still installed the the housing assy
69 RS SS L78 conv
69 RS SS ZL1
69 L78 Chevelle conv
69 L78 Nova
69 L34 Nova
67 SS Chevelle
73 Trans Am
