Old 09-23-2018, 12:48 AM
big gear head's Avatar
Default Sticky rubber parts
I've got a rubber horn pad from a SS steering wheel that has got sticky over time. I've also had a few rubber steering wheels that got sticky. Is there anything that can be done about this?
Freddie
ruralrte66 (09-24-2018)
Old 09-23-2018, 05:41 PM
A good car wax. I use Zymol.
I had a CL600 with incredibly gummy buttons on the horn shroud. Replacement would have been very expensive.
Rub it in on a small area with just your finger. As the gum or sticky residue starts to dissolve, take it off with a soft cloth. You may have to go at it two or three times before it comes completely clean.
The Following 2 Users Say Thank You to Lynn For This Useful Post:
big gear head (09-23-2018), ruralrte66 (09-24-2018)
Old 09-23-2018, 07:01 PM
Thanks, I'l give that a try. I was thinking that something like acetone might work, but was afraid to try it.
Freddie
Old 09-23-2018, 08:32 PM
marxjunk marxjunk is offline
i use crest tooth paste..very gentle, what ever is in it works well..just dob some on work in with your hands, and rinse..with come out like new..and minty fresh...its incredible to use to buff glass and plastic too..incredible amount of uses..
some old dude in the 80 hustled steering wheels, said it was the best thing he ever used, i tried it, and agree totally..
Mark
The Following 3 Users Say Thank You to marxjunk For This Useful Post:
big gear head (09-24-2018), John (09-24-2018), ruralrte66 (09-24-2018)
Old 09-24-2018, 01:38 AM
ruralrte66 ruralrte66 is offline
I have the same problem , was wondering what to try.
Thanks Gregg
Old 09-24-2018, 02:16 PM
firstgenaddict's Avatar
I just removed the gum off a horn button for a 4 bar Z28 steering wheel using KABOOM foaming cleaner AND a toothbrush.
Denatured alcohol also will not harm vinyl or rubber... it is used for cleaning rubber and vinyl in the printing industry. I use it to remove all kinds of sticky and tacky gunk.
~JAG~
NCRS#65120
NUMEROUS Lemans blue Camaros,
& a Chevelle or two...
The Following User Says Thank You to firstgenaddict For This Useful Post:
Old 09-24-2018, 02:41 PM
After cleaning, does this last or is this something that has to be done often?
Freddie
Old 09-24-2018, 03:19 PM
It will last for quite some time...
FWIW what is happening is the plasticizers (the additives which make it flexible) are leeching out of the porus material.
Here is a 69 DASH PAD which was so sticky that it would pull lint from a cloth...
Cleaned with denatured alcohol...
~JAG~
NCRS#65120
Old 09-24-2018, 04:00 PM
fiveforty fiveforty is offline
I use fast orange hand cleaner on cushion rim steering wheels, works excellent.
The Following 2 Users Say Thank You to fiveforty For This Useful Post:
big gear head (09-24-2018), firstgenaddict (09-24-2018)
Old 09-24-2018, 07:04 PM
mockingbird812's Avatar
Ask Eddie (enio45) what he uses for those Ferrari he keeps company with. Even they're prone to stickiness!
Sam...
