Old 09-02-2018, 02:27 PM
R68GTO R68GTO is offline
Default 4346 carb questions
Did 4346's come with the internal brass fuel filter, gasket, and spring in each inlet port?
Does the fuel line Y-block bolt to an intake bolt via a bracket or is it just hanging out, supported by the fuel lines on a 1969 L72 427?
Old 09-03-2018, 12:41 AM
bbbentley's Avatar
1st question - yes
2nd question - by the time your car was made it had a bracket as part of the fuel block. It was crimped onto the bottom of the fuel block and made out of stamped steel. The intake used a stud in place of a regular intake bolt that the bracket was affixed to and secured with a nut and lock washer. Early cars, prior to (guessing) Feb. 69, did not have the bracket and the block just hung there supported by the fuel lines.
FULL OWNER HISTORY
Old 09-03-2018, 11:20 AM
Thanks Bentley!
