Old 08-28-2018, 01:45 AM
ALLZS ALLZS is offline
Default 12 bolt housings
are 66-67 chevelle 12 bolt housings a 2 year only deal or will others fit or will 68 & up chevelle work or impla ?
Old 08-28-2018, 02:06 AM
ban617 ban617 is offline
Hi , I think they actually started making them in 65 and yes they are narrower than a 68-72 if you need one I know a gentleman that has one
Old 08-28-2018, 02:56 AM
I have a friend that just picked up a 67 needing a 12 bolt for it any leads would help
Old 08-28-2018, 03:09 AM
big gear head's Avatar
'65 and '66 Chevelle housings are the same and have flat spring perches with a bolt that holds the spring in place. '67 is the same width at 60 inches, but has the later spring perch with the raised center. '68 to '72 are all the same and are 61 inches wide. All of them will interchange, but tire clearance may be an issue if you are using wide tires.
Freddie
m22mike (08-28-2018)
Old 08-28-2018, 09:13 PM
L72Biscayne L72Biscayne is offline
I have a mint original paint ,rust free 67 axle with new 4:11 gears installed. (617) 269-8247 David.
1970 Z28 Citrus green CW 3:73 1970 Ls6 Cy 3:31 14K miles 1968 Biscayne L72 M22 952 actual miles. 1966 Biscayne L72 3:73 1966 Chevelle L78 M22 4:56
