Old 08-17-2018, 10:57 PM
dlv4540 dlv4540 is offline
Default 1969 396-375HP Camaro Engine
1969 396 4 bolt Chevrolet engine casting number 3969854 dated G-2-9 and is a standard bore 402 with front pad stamped T0725JH and down by the oil filter is 9N680592. Block was cleaned and magged and in excellent condition with no damage. 3919840 heads cleaned and magged in stock condition dated C-26-9 and E-5-9 and have the studs and guide plates along with original valves and L stamped rockers. 3933163 aluminum intake cleaned with center plenum removed dated 6-17-69. Original solid lift camshaft, oil pan, 8 inch timing cover, 6223 steel standard crankshaft, 11 to 1 pistons with 3/8 dimple rods and 8 inch #3870325 harmonic balancer. Asking $6500 or best offer and can ship if you cannot pick up. Any questions I can be reached at 330-770-2517.
Dennis Vugrinovich
