Old 07-18-2018, 03:04 AM
DarrenX33's Avatar
Default Crappy idle, misfire on one cylinder.
Anyone one have any thoughts on this?
Plug 2 is not firing. All others look fine. I tried the following to get 2 to work..
1) plug swap 1 to 2, no change
2) new plug wire, no change
3) tighten up plug, no change
4) change cap, no change
5) change rotor, no change
6) change timing, no variation of timing brings 2 back.
7) change capacitor, no change
8) watched for spark on plug while grounding it. no spark until you hit about 1500 rpm, then spark is there but looks weak. Perhaps my spark is weak all around.
Distributor was just rebuild/restored by Jerry MacNeish. I have new plugs, wires, coil, engine harnesses. Totally stumped.
1969 Z28
1972 Corvette
Old 07-18-2018, 04:59 AM
Mr. Chevy's Avatar
Maybe you have a faulty coil even though its new... Are the points ok??
Rich
Old 07-18-2018, 11:56 AM
Woj's Avatar
Woj Woj is offline
It seems like the coil is the only thing you have left to change. Maybe swap out the coil for a known good coil? One thing I have found in the past is that most point sets, even the later GM are junk. I was told to give Echlin points a try, I did and really do like the quality of their points. I bought these at NAPA.
Good luck and let us know what you find.
Old 07-18-2018, 11:58 AM
1967 4K's Avatar
1967 4K 1967 4K is offline
Do a cylinder compression check. Could be in the valve train, hope not.
Richard
1967 Camaro SS 396/375 4K
Old 07-18-2018, 12:12 PM
This is what I use on all my cars. As Phil said, today's points are junk.
Your very first tow ride home and you will throw away them points.
https://www.lectriclimited.com/break...nversion-85309
Old 07-18-2018, 12:38 PM
cook_dw's Avatar
cook_dw cook_dw is offline
Was it running fine before the distributor rebuild? Swap distributors would be the first thing I'd do if the previous statement was true. If it cleared up then I would send it back. But FWIW its more than likely the points. Local autoparts store used to have points/condenser kit where the condenser was made onto the point plate and they were great. Never had an issue with them. Blue Streak was the name but I wanna say it was owned by Standard Motor Ignition or Products..
Old 07-19-2018, 01:29 AM
L78steve L78steve is offline
If the distributor was run on a Sun machine and it tested good you can rule the Dist. out as being the problem, points included.
Old 07-19-2018, 01:36 AM
cook_dw's Avatar
Never assume.. You will make an ass out of....... Well you get the point.
As the great President Reagan once said. Trust but verify.
Old 07-19-2018, 01:44 AM
tunes's Avatar
tunes tunes is offline
Change the coil. This sounds like a friend's car last year that suddenly wouldn't run. It had a weak spark and would try to start. The culprit was the coil.
Robert
_______________
1969 Chevelle SS396 L78 M21 4.10
2023 Stingray Coupe Z51
Old 07-19-2018, 02:27 AM
Lee Stewart's Avatar
Would the engine experience the same symptoms if either the lifter got stuck or a valve spring broke?
