Old 07-13-2018, 12:52 PM
rlw68's Avatar
rlw68 rlw68 is offline
Default "3905569 washer-sealing" on 69 Camaro
The 69 Camaro AIM (UPC 4 B3) shows a sealing washer on the rear shock bracket for each of the 2 bolts. When the brackets were removed the old washers had either deteriorated or were never there. Is this just a neoprene washer?
Rob
Rob
1969 Camaro Z/28. Norwood 02D. Lemans Blue
Old 07-13-2018, 01:55 PM
bbbentley's Avatar
https://www.ecklerscorvette.com/1959...sher-rear.html
Dimensions- .090 X .281 X .800 in.
FULL OWNER HISTORY
Old 07-13-2018, 05:51 PM
rlw68's Avatar
Originally Posted by bbbentley View Post
Thanks Benny. On closer inspection (I took my glasses off ) there appears to be a very thin washer left on one bracket. The thickness and diameter seem to agree with you dimensions but it doesn't look anything like the part on Ecklers. Maybe they have the wrong picture or p/n?
Rob
Old 07-14-2018, 12:33 AM
I have always just used a very thin strip of dum dum (3M strip caulk). It seals as well or better than rubber, and won't dry out. That's what you need to put around the large hole identified as 60a in the pic above. As long as you have it out, just roll out two more tiny strips for the bolt holes. Can't be seen once installed.
The Following 2 Users Say Thank You to Lynn For This Useful Post:
m22mike (07-14-2018), rlw68 (07-14-2018)
