Old 06-21-2018, 12:45 AM
MailOrderMotion MailOrderMotion is offline
Default 12 bolt service replacement housing.
Is there such a thing ? I just pulled a really nice multileaf E 28 0 cast, # 9341 12 bolt out of a '68 camaro. I can find no evidence of an assembly stamp on it. Did they move the stamp to a different location on the later housings?
Old 06-21-2018, 02:26 AM
bbbentley's Avatar
I bought some parts a couple of years back from a guy. In his barn were 5 camaro 12 bolt housings. The one in the corner behind some plywood, the owner told me his Dad bought that housing over the counter. No stamping. I would assume a complete assembled rear would have a stamping to ID gear ratio. To answer your question, if it was a warranty, then it was a just the housing or one bought over the counter?
Also, look at the backing plate flange on the rt. and determine if the tube has twisted and the numbers are not in the area cleaned?
FULL OWNER HISTORY
Old 06-21-2018, 01:28 PM
We are thinking the same way. It makes sense that the only way this came without an assembly stamp was if it was a bare housing. I will spend some time with it today with some stronger lighting. There isn't anything funky with the tubes, so I can rule that out. The guts were no real help as the dates were way off. It does have a nice GM 4;10 gearset dated 5 69.
Old 06-21-2018, 07:15 PM
Caseys69 Caseys69 is offline
Yes, ive seen "NOS" Chevelle 12 bolt housings before. One dated early 70 and one dated 72
Old 06-21-2018, 10:08 PM
Default Stamp
I looked this over with a strong light and found absolutely nothing. It's like getting a block with a fresh blank pad. Too bad only the late year '70 Nova guys would benefit.
Old 06-22-2018, 03:10 PM
markjohnson's Avatar
Several years back, I had a 1972-dated Camaro/Nova 12-bolt leaf spring housing with no tube stamping. I thought it was an interesting piece because Chevrolet wasn't putting 12-bolts in those particular cars anymore.
Old 06-23-2018, 01:30 AM
Had dinner with a friend tonight and he recalls having a 72 dated 67 mono leaf 12 with the traction bar mount go through his stock.
Sounds like my question is answered. Thanks everyone !
Dave
