Old 06-13-2018, 12:09 AM
R68GTO R68GTO is offline
Default Cowl Flapper Actuator position
Can someone help a newb on how a 69 Camaro cowl hood flapper actuator is oriented the assembled properly? I see that the flapper frame bolts in from the windshield side and the actuator lines up with the round hole on the underside/back of the hood. From photos of restored cars I see that the solenoid wire goes through a rubber grommet that fits in that hood hole. Which direction does the actuator spade point? up/down/pass side/drriver side?
Old 06-13-2018, 08:10 AM
Straight down so that it will line up with the harness through the grommet in the hood.
Old 06-13-2018, 12:15 PM
William William is offline
Many questions can be answered by acquiring a copy of the factory assembly manual.
http://www.drclassic.com/catalog/Camaro/Book
Old 06-13-2018, 01:22 PM
cook_dw's Avatar
cook_dw cook_dw is offline
Or download it for free..
http://www.camaros.org/forum/index.php?topic=9433.0
FYI CRG has chock-full of useful information.
http://www.camaros.org/index.shtml
The Following User Says Thank You to cook_dw For This Useful Post:
R68GTO (06-13-2018)
Old 06-13-2018, 04:25 PM
Thanks all! That should keep me out of trouble for a while!
