Old 06-03-2018, 03:44 AM
big gear head's Avatar
Default Front brake caliper bolt torque
'69 Camaro. I need to check this stuff more often. Just by accident I found out that the bolts that hold my front caliper brackets on were loose. I could turn them with my fingers. It's been about 25 years since I put these bolts in. I had Locktite on them, but for some reason they backed off a little. I need to know what the torque specs are for these bolts. There is one large bolt at the top and then the two smaller bolts that also hold the steering arm on the spindle. Thanks for your help.
Freddie
