Old 05-26-2018, 03:45 AM
scuncio's Avatar
scuncio scuncio is offline
Default '67 Chevelle SS396, Wrecked in '70 and garaged ever since...
Check out the interior, looks brand new. Trans and rear are original...you could do worse for the $8500 opening bid.
Link to 1967 Chevelle SS396
Old 05-26-2018, 05:00 AM
427TJ's Avatar
427TJ 427TJ is offline
The replacement fenders are from a 396 car too.
Old 05-26-2018, 01:31 PM
"Vehicle had severe front end damage" and not one picture of the front end???
Bill Pritchard
Old 05-26-2018, 03:17 PM
luzl78 luzl78 is offline
Needs a frame
Old 05-26-2018, 03:43 PM
big gear head's Avatar
I'd probably buy that if it wasn't so far away. I've got a frame.
Freddie
Old 05-26-2018, 05:43 PM
PeteLeathersac's Avatar
Subject VIN 138177Z126034
Cool car but may look vastly different w/ an eyeballs view?
Pass' door position may indicate cowl damage also tone changes pre accident paint repairs?
Note differences @ driver's door/quarter also pinstripe down pass' side...almost looks clear coated which may question accident date?
~ Pete
ruralrte66 (05-26-2018)
Old 05-26-2018, 09:06 PM
On a positive note, it's refreshing to see the square turquoise "GM" sticker on the trailing end of the driver's door.....on a car that it truly belongs on
Bill Pritchard
Old 05-26-2018, 10:20 PM
Fast67VelleN2O's Avatar
Pretty cool car, but with no nose photos, I bet it's pretty bad... Like damaged cowl bad. Curious as to why it has a woodgrain strip on the dash.
Day 2 is Life.
Old 05-26-2018, 11:46 PM
scuncio's Avatar
Guessing it was hit pretty hard, but definitely looks fixable if you had access to a good frame guy.
Old 05-26-2018, 11:58 PM
67since67's Avatar
If you look closely behind the headlight and wiper knobs, the proper trim rings, molded into the plastic SS strip, but separate pieces on a Malibu woodgrain metal strip, are absent. A good guess would be that the owner preferred the woodgrain and swapped it, but didn't get the rings.
By the way, no original M22 in a '67 Chevelle as claimed.
