Old 05-03-2018, 06:18 PM
XXXGoldL34M20's Avatar
Default 1970 Chevelle Original Brake Booster Bracket GM part #3952757 Bracket / "C" stamp
Extremely hard to Find Master Cylinder Brake Line Bracket that gets mounted behind the Brake Booster on the booster's main rear frame. This holds the two main lines into place and is an Original GM part # 3952757 Bracket with "C" stamp. Comes with Original "GL" bolt and S Clip for the two lines to be held further down behind the Brake Booster. The original Cut Rubber inserts are also still in place.
$75 USD with Free Shipping.
Old 05-03-2018, 06:24 PM
*Sold*
Old 10-08-2018, 09:37 PM
Arrow
Old Thread but bumping it up again as I found another one of these today,
Extremely hard to Find Master Cylinder Brake Line Bracket that gets mounted behind the Brake Booster on the booster's main rear frame. This holds the two main lines into place and is an Original GM part Stamped 3952757 on the bottom Bracket with "C" stamp on top. Comes with Original "Anchor" Emblem bolt and original Cut Rubber inserts.
$70 USD with Free Shipping.
*SOLD*
