Old 04-24-2018, 11:48 AM
chris slawski chris slawski is offline
Default 69 Camaro 4 speed conversion COMPLETE
PART'S ARE EXCELLENT ,QUALITY, USED, REFURBISHED & NEW "CAR" PARTS. THERE ARE NO SHORT CUTS HERE.
WILL FIT CAMARO NOVA CHEVELLE EL-CAMINO AND MANY OTHER CHEVYS ALSO.
WILL FIT ANY EARLY CHEVY ENGINE WITH THE WITH THE LARGE BELLHOUSING , 283, 302, 305, 307, 327,350,396 406, 427 WITH THE LARGE 168 tooth flywheel
SET UP FOR BIG BLOCK OR SMALL BLOCK, DO YOUR HOMEWORK!!!!!
VERY NICE FRESH REBUILT MUNCIE WIDE RATIO TRANSMISSION. M-20, 2.52 FIRST, 1.88 SECOND, 1.46 THIRD, AND 1.00 FORTH. 3.11 REV WIDE RATIO, SET UP TO FIT NOVA CHEVELLE CAMARO THIS IS FOR A CONSOLE CAR, BUT CAN ALSO BE USED WITHOUT.
THIS REBUILD HAS THE ORIGINAL USED GEARS, AND ALL NEW SMALL PARTS!
TRANSMISSION WAS COMPLETELY DISASSEMBLED , CHEMICAL WASHED, AIR DRIED, GLASS BEADED, AIR DRIED, AND CLEAR COATED. IT ALL CHECKED OUT VERY GOOD.,
THEN IT WAS REASSEMBLED. EVERYTHING NEEDING REPLACED WAS REPLACED WITH ALL NEW SMALL PARTS, BUSHINGS, NEEDLE BEARINGS, SNAP RINGS, NEW SLIDER SPRINGS, SLIDER KEEPERS, TWO NEW SLIDERS, NEW FRONT RETAINER, NEW CLUTER GEAR MAIN SHAFT, GASKETS, SEALS, AND NEW SYNCROS.
KEEP IN MIND WHAT IT WOULD COST YOU TO PUT THIS SET UP TOGETHER WITH TODAY'S INFLATED PRICES AND KNOW THIS IS A GOOD PRICE.
ITEMS YOU WILL RECEIVE ARE'
MUNCIE M-20 WIDE RATIO ALL ALUMINUM 4 SPEED TRANS. , ALL ORIGINAL 3925660 MATCHING NUMBER CASE
GLASS BEADED ,CLEAR COATED!!! NICE!!!!
NICE...... TIGHT! ORIGINAL RECONDITIONED HURST SHIFTIER
NEW........ SHIFTER BOLTS
NEW....... CAMARO CHEVELLE SHIFTER MOUNTING BRACKET
NEW ......ORIGINAL SHIFTER MOUNTING (BRACKET BOLTS) AND (LOCK WASHERS)
NICE...... SHIFTER LEVERS AND LINKAGE,
NEW..... (HURST) SHIFTER BUSHINGS AND PINS,
NICE......ALL SHIFTIER LINKAGE.
NICE....... ORIGINAL RECONDITIONED 621 BELLHOUSING (FOR 168 TOOTH FLYWHEEL), BIG BLOCK OR SMALL BLOCK CAR BELL HOUSING,
NEW........BRAND NEW 168 TOOTH FLYWHEEL
NEW........BELL HOUSING DUST COVER
NEW........ CLUTCH FORK BOOT,
NICE ........ORIGINAL CLUTCH FORK,
NEW........ BELLHOUSING TO BLOCK BOLTS AND LOCK WASHERS
NEW........BELLHOUSING TO TRANSMISSION BOLTS AND LOCK WASHERS
NEW......11" CLUTCH PACK, (PRESSURE PLATE, CLUTCH DISK, THROW-OUT BEARING FOR SMALL BLOCK OR BIG BLOCK,
NEW....... (CLUTCH TO FLYWHEEL), LOCK WASHERS, HARDENED FLYWHEEL CLUTCH BOLTS.
THIS IS A VERY NICE QUALITY SET UP! ONE OF THE BEST YOU WILL FIND!
69 Camaro floor shift column
69 Camaro clutch and brake pedal with bracket
Aftermarket bell crank and bell crank install kit
$2950.00
Located in Medford Lakes NJ zip 08055
Photos to follow
