Old 03-06-2018, 05:54 PM
octard octard is offline
Default JL8 Style Front and Rear Brakes (for standard drum brake flange 10/12 bolt rearend)
This offering provides the following all new or unused rebuilt items:
* 2 Front Calipers (left and right), Corvette Delco Moraine. Unused after purchased as rebuilt.
* 2 Rear Calipers, Corvette Delco Moraine. Unused after purchased as rebuilt.
* 2 New Front Rotors. (reproduction)
* 2 New Rear Rotors. (reproduction)
* New Front Brake Pads.
* New Rear Brake Pads.
* 2 Front JL8 Style Caliper Brackets. (reproduction)
* 2 Front Intermediary Hard to Flex Line Adapter, Similar to Original JL8 Style Part.
* 2 Rear JL8 Style Caliper Brackets. (equates to 2 right rear Corvette caliper brackets)
* 2 Rear Emergency Brake Mechanisms. (Unused after purchased as new/rebuilt)
* Rear Emergency Brake Cables. (reproduction)
* 1 Driver Front Brake Backing Plate. (modified from standard front disc backing plate)
* 2 Rear Brake Backing Plates. (Corvette reproduction)
* 2 Front flex brake lines.
* Rear hard brake lines.
- No front spindles included. Need to use your own disc brake spindle.
- No front hubs included. Need to use your own drum brake hub.
- No rear axle provided. Made to work on standard drum brake flange. 10 or 12-bolt rear axle flange.
NOTE: As noted in one of the photos, an insert was made and machined to allow the correct JL8 style rear caliper bracket to be used on a smaller bolt pattern, standard drum brake 10-bolt or 12-bolt rear axle housing end flange.
This item can be shipped on a palette or wood crate, but the boxing/paletting and shipping cost to be calculated, based on location and shipping options chosen by the buyer.
Asking $1450, before shipping.
Prospect or Buyer to call 408-590-4520 with any questions.
Attachments - The Supercar Registry JL8 Like Brakes Photo 5.jpg JL8 Like Brakes Photo 4.jpg JL8 Like Brakes Photo 3.jpg JL8 Like Brakes Photo 2.jpg
Tags
jl8 brakes
