Old 02-22-2018, 05:01 PM
Default 1969 Camaro #309 "US" Master Cyl. & Brake Booster
Complete original set up never taken apart.I wiped it down to the best I could.
Machined pad shows "US"stamping.
I took this off of a totaled Big Block 396cid.Camaro @ Victory Auto Wreckers in 1988.I will not release it's VIN# for that very reason,as it & the cowl tag were later ripped off when I returned.
This was also used on the '69 Z/28s.
*#5468309 Master Cylinder dated 146~May26th 1969.Has it's original lid & bail clips.
*#9204 Booster dated 155~June 4th 1969.DELCO MORAINE wording on right side and up @ 2 O'clock position.Rear rod plastic cup still attached and not cracked.
*Pedal Rod shows F9,for F body,1969.
*#8524 U-Bkt. on end with makers mark.
*Proportioning Valve & bkt. still attached.
*Distribution Block & bkt. still attached.
*Check valve still attached with 3 dots.
$850 for everything you see.
Shipping is extra,unless picked up in person.I do travel alot,so I might be able to bring closer to you too.
Rick [email protected]
