Old 01-31-2018, 01:49 PM
ALLZS ALLZS is offline
Default Drive shaft ballance weights
Does anyone know of a vendor that sells the original style ballance weights for the driveshaft not flat washers thanks
Old 01-31-2018, 07:07 PM
Did you try NEAPCO?
Old 01-31-2018, 07:55 PM
no I did not who is that
Old 01-31-2018, 08:57 PM
a driveshaft company. Type in Google search or EBAY and they have weights and other stuff for sale. Maybe call them.
Try this in Belleville, MI. 734-447-1380.
Old 02-03-2018, 04:52 PM
resto4u resto4u is offline
you could make them, just a piece of steel and form it to the driveshaft curve.
Old 02-03-2018, 05:28 PM
Unreal Unreal is offline
They are normally projection welded, with the projections welded to the prop shaft, and on many weight designs, the weights have dimples on the outside, where the projections were stamped. So if you wanted them to look "correct", you would need to duplicate the dimples.
