Old 01-07-2018, 03:04 PM
Default Chevelle rear ends
Will a 67 Chevelle 12 bolt physically fit in a 69?
65 Corvette Coupe L78
69 L71 Roadster Survivor
69 Z/28 RS (Sold)
69 Dodge Charger R/T
70 W30 442 Auto Air Survivor
2016 Z06 Coupe M7
70 AAR Cuda (Sold)
69 L78 Chevelle (Sold)
Old 01-07-2018, 03:50 PM
Yes,it should bolt right in for you,no problem.But be advised a '67 Chevelle rearend is just about 5/8 inch narrower on each side than the 68-72 rears...so you'll have more room for a fatter tire on the outside part of the rim then.
Here's some technical stuff that I gathered before doing a swap on 1 years ago,that may or may not help you:
*1964-67 chevelle rear end housings measured 56.5 inches from flange to flange, and 60.5 inches total length with the drums in place.
*1968-72 chevelle rear end housings measured 58.5 inches from flange to flange, and 62.5 inches total length with the drums in place.
*Rear spring mounting pads on the 64-67 rear ends used a flat pad with a hole drilled in the center, the 68-72 rear ends have a circular spring mounting pad, that are 3/4 of an inch higher that the flat pads.
*1967 was a transition year in which the A-body cars might have a 64-66 style rear end, a 68-72 style rear end, or a "hybrid" rear end that will have the 58.5 inch width, but will have the early spring mounting pad and trailing arm brackets.
*Rear upper control bushing eyes differ,and the position of the bushing eyes will differ. 68-72 rear end housings will have a 3/8 inch forward positioning,which is farther than the 65-67 rear ends.
*1965-67 upper trailing arms are 1 inch shorter and will not fit into 68-72 A-body cars, 68-72 A-body cars have longer upper arms and when switching upper arms the pinion nose angle will be affected.
Old 01-07-2018, 04:05 PM
big gear head's Avatar
I'd like to correct one thing here. The width of the '64 to '67 Chevelle rear end is 60 1/4 inches with drums and the '68 to '72 rear end is 61 1/4 inches with drums. The axle length of the early rear ends is 29 1/8 inches and the later axles are 30 1/8 inches. I don't know how that 62 inch width got started on the internet, but it's everywhere and it's not correct. There is exactly 1 inch overall difference in the early and late Chevelle rear ends.
Freddie
Old 01-07-2018, 04:19 PM
bigsixman bigsixman is offline
I agree.
69 camaro X11, 56,000 miles, original HO paint
67 camaro SS/RS, Butternut yellow, bench, fold down
Old 01-08-2018, 12:00 PM
Mr. 70
You may recall we discussing in an earlier thread the rear end in my 69 L78. The build sheet calls for a KK there is a CF 3.31 installed now. The date code on the axle tube aligns with the build date of the car, but the casting number of the differential is for a 67. (3894939) I have caught up with the second owner of 44 years and he states he never changed the rear end. I am the third registered owner. I assume that the rear end must have been changed by the original owner. I am the third registered owner. There were two flippers before me. There is zero evidence of this rear end being touched in the recent past. What I am trying to figure out if this rear end is a 67 by visual glues, and you guys have given those to me. I appreciate it. I would like to find a correct dated KK for the car if possible.
Thanks
69 Z/28 RS (Sold)
2016 Z06 Coupe M7
70 AAR Cuda (Sold)
Old 01-09-2018, 11:43 AM
JpMotorsports JpMotorsports is offline
Send a message via Yahoo to JpMotorsports
Man I'd love to find a solid 67 12 Bolt for my 67
1982 Pontiac Grand Prix- Dove Gray (Turbo LS swap in the works!)
1967 Chevelle SS396- Tuxedo Black- SOLD
1972 Oldsmobile 442 W29 Convertible- Sunfire Yellow- SOLD
1969 Chevrolet Chevelle/Malibu- Dover White- SOLD
1986 Oldsmobile Cutlass Supreme- Silver- SOLD
1987 Chevrolet Monte Carlo SS- Maroon- STOLEN
Old 01-09-2018, 11:58 AM
Many of them have been modified and put under Camaros. The '65 to '67 Chevelle 12 bolt is the same width as the '67 to '69 Camaro rear end.
Freddie
Big Block Bill (01-09-2018)
Old 01-10-2018, 04:04 PM
L72Biscayne L72Biscayne is offline
Jpmotorsports I sent you a private message.
1970 Z28 Citrus green CW 3:73 1970 Ls6 Cy 3:31 14K miles 1968 Biscayne L72 M22 952 actual miles. 1966 Biscayne L72 3:73 1966 Chevelle L78 M22 4:56
Old 01-11-2018, 01:15 AM
JP Motorsports, happy to sell you this rear end if I can find a KK for my car.
69 Z/28 RS (Sold)
2016 Z06 Coupe M7
70 AAR Cuda (Sold)
Old 01-11-2018, 04:52 PM
Got you PM's Thank you guys!
