Old 11-12-2017, 08:09 PM
ALLZS ALLZS is offline
Default turn signal flashers
are any of these factory correct for turn signal & emergency flasher ?
Attachments - The Supercar Registry rps20171113_155759.jpg DSCN6210.JPG DSCN6209.JPG DSCN6208.JPG
Old 11-13-2017, 12:51 AM
resto4u resto4u is offline
The two metal round ones are factory style for 67-69 camaro. Assembly line original were pastel blue. This is based on original owner, un-restored cars that i have seen or owned.
Old 11-13-2017, 11:24 AM
ZLP955's Avatar
ZLP955 ZLP955 is offline
What make/model/year? If it's for a 69 Camaro, I did some research a few years back. From the limited number of replies from owners with original cars, seemed the most likely flasher numbers were Tung-Sol 224 (turn signal) and 552 (emergency 4-way), and possibly Signal-Stat 175 and 170 too. The 1969 AIM calls up several different part numbers, and I wasn't able to find out a definitive answer, nor if there was a difference between standard or RS models. I recall the turn signal flasher was load-sensitive, giving an audible sign (change in rate) that a bulb had blown, whereas the 4-way was constant rate.
None of the 'believed original' assembly-line correct units had 'DOT' on the can, so this was probably a change introduced in the '70s.
Tim in NSW, Australia
Old 11-13-2017, 12:25 PM
Working on a 1969 camaro where the originals the metal can or the plastic housings
Old 11-13-2017, 03:50 PM
Billohio Billohio is offline
I am sure theres pictures of these on the CRG site. I will see if I can remember and get a picture of the one on my Z today. I am thinking it was pale blue plastic
Bill
Old 11-13-2017, 06:24 PM
ZLP955's Avatar
Best I could determine was T-S 552 (metal) for the 4-way in the fuse block, and T-S 224 (pale blue plastic) for the turn signal in the clip on the under-dash brace.
Old 11-13-2017, 07:59 PM
I doubt this has ever been out. Hip too messed up to find the plastic one
Bill
