Old 11-09-2017, 02:22 AM
crash crash is offline
Default F/S Nash/Richmond street 5-speed
Nash/Richmond gear 4+1 street 5-speed, 3.27-1st gear, 1 to 1 5th gear, 26 spline input/ 32 spline output, with Hurst shifter...
Fresh rebuild, bearings, brass, sliders, ect...
I get $2450.00 plus shipping... E-mail for pictures [email protected]
Thanks... Crash... can deliver to MCACN in Chicago Nov.18
Old 11-10-2017, 03:40 PM
jerry455 jerry455 is offline
Does anyone have any experience fitting one of these transmissions into a 1969 Z/28?
Basically swapping out a factory Muncie F-Body car for the DN 5-speed-
Fitment issues? tunnel/floor pan mods? Shifter/console? Crossmember?
I like the idea of the steep 1st gear & run a 3.08 in rear for hi-way cruising.
Thanks for any input.
Jerry
The Following User Says Thank You to jerry455 For This Useful Post:
mike1971 (11-11-2017)
Old 11-10-2017, 03:58 PM
ssl78 ssl78 is offline
I have one in my car with a 323 gear and thats to much gear a 2;73 would be perfect I think. sits further back by a couple of inches than stock trans. Crossmember had to be modified a little and console moved back
69 RS SS L78 conv
69 RS SS ZL1
69 L78 Chevelle conv
69 L78 Nova
69 L34 Nova
67 SS Chevelle
73 Trans Am
The Following User Says Thank You to ssl78 For This Useful Post:
jerry455 (11-10-2017)
Old 11-12-2017, 01:17 AM
scuncio's Avatar
scuncio scuncio is online now
I am almost done installing one in a 68. Requires no floor or console mods if you modify the shifter and shifter mount. The cross member mod is not difficult and requires a Turbo 400 cross member as raw material. All in all pretty straightforward if you can weld and know someone with a mill.
jerry455 (11-12-2017)
Old 11-13-2017, 04:06 PM
Doug Nash designed the 5-speed to be used with 3.08 gears on the street...
If you go to this web site www.pozziracing.com they go over the shifter and cross member modifications...
I have a blue print from another site for a 1st gen. Camaro shifter mount also...
Hope this helps... Crash
Old 11-13-2017, 07:25 PM
Me and Dan Vasic did a build on my 1979 Z28 and put one of these in it, It was easy as pie.
Dan Vasic maybe you could post the link from yenko with the sub frame and trans installed?
Old 11-14-2017, 03:20 AM
Is this the more friendly street tranny or is it the all out drag race "crashbox" version?
Paul
Old 11-15-2017, 04:37 PM
Nash/Richmond 4+1 "STREET" 5-speed, the "friendly" one...
