Old 10-18-2017, 11:05 PM
6667ss138 6667ss138 is offline
Default 69 Z/28 manual steering box
I am looking for a April to June dated manual Z/28 close ratio steering gear box.
Thank you!
Old 10-19-2017, 12:50 PM
Manual box was the same as a standard non fast ratio, the pitman arm was 1/2" longer for the Z-28, from 5.25 to 5.75 inches. This should make your box search easier.
Paul
Old 10-19-2017, 02:30 PM
Thank you!
Old 10-19-2017, 03:02 PM
jl8z28 jl8z28 is offline
I have one out of a 69 Z28 that I was holding on to its been refinished and rebuild to concourse standards I can check the date but it's not going to be cheep if you are interested
Old 10-19-2017, 05:43 PM
BLACKLS5 BLACKLS5 is offline
What's the casting number on the gear supposed to be? I have a 5679142 with a date of A1759 if that's what you're looking for.
Old 10-19-2017, 11:02 PM
I will double check but it sounds to me like the correct casting number and if I am decoding the date correctly it would be the 175th day of 1969 which was June 23rd. That would be perfect for my 07A car. Can someone please confirm if I have decoded this correctly? If it is correct for my car I will PM you for a price. I do have a correct Z/28 pitman arm that I've had for years so this would fix me up.
Thank you!
Old 10-19-2017, 11:04 PM
Yes, please check your date. I will be doing a concourse restoration on my 69 Z, so I am interested. Thank you!
Old 10-20-2017, 12:15 AM
6667ss138,
The box BLACKLS5 has is the correct one.....If your happy with that date, which is also correct like you indicated then go for it. Dave
67 Z/28 Butternut Yellow
69 Z/28 Rally Green
69 Z11 Pace Car
2010 2SS RS Aqua Blue
68 Z/28 Lemans Blue
2019 Corvette Grand Sport
68 SS Lemans Blue
69 RS/Z28 Maroon JL8
66 Corvette Ermine White L75
Old 10-20-2017, 12:20 AM
Originally Posted by luv2sixty9 View Post
6667ss138,
Thank you, Dave!
Old 10-20-2017, 12:56 AM
I checked the date on mine and it is 332 of 68
