Old 10-09-2017, 03:42 PM
dlv4540 dlv4540 is offline
Default 1970 396-375HP Warranty Exchange Block & Parts
I have a standard bore 396 warranty exchange 4 bolt block casting number 3969854 dated H-21-9 with a CE0XXXX stamping on the front pad. This could be used for a 1969 or 1970 application. The block was cleaned and checked with no damage and clean cylinders which should stay without needing bored over. I also have the correct 3963569 low profile aluminum intake and the 3919842 aluminum heads if somebody wanted to make it a L89 optioned block. $2500 for the block, $500 for the intake and $3000 for the bare aluminum heads with screw in studs and guide plates only dated in late 1968. Can ship if you cannot pick up and can provide pictures. 330-770-2517
Dennis Vugrinovich
Old 10-09-2017, 03:44 PM
