Old 09-01-2017, 12:51 AM
all_about_cars's Avatar
all_about_cars all_about_cars is offline
Default 69 small block engine hardware
Engine hardware,just removed from a 69 327
Intake bolts,with engine lift hooks
Head bolts
Distributor hold down and bolt
Timing cover bolts
Fuel pump bolts
Fuel pump mount plate and bolts
Oil pan bolts
Oil pan drain plug
Balancer bolt
Crankshaft pulley bolts
Water pump bolts
Exhaust shield bolts
Thermostat bolt and stud with nuts
Engine mount to block bolts
All bolts are just removed and shipped dirty,but bagged and labeled
Complete set 260.00 shipped lower 48
I have other individual hardware if there is something you need.
Thanks Eddie
