Old 07-12-2017, 05:32 PM
HawkX66's Avatar
HawkX66 HawkX66 is offline
Default 65 vs 72 BBC short block pros & cons
I have a
-Dave
Semper Fi!
69 Camaro SS396 L34 X66
Old 07-13-2017, 12:25 PM
L78steve L78steve is offline
If your 65 block is cast prior to August then its the "Fang" block. The cylinders can be opened up to .125 beyond 427 bore. Its a keeper.
August 65 on, the block had the same casting number for some unknown reason but lost the thick cylinders and the fangs.
Old 07-13-2017, 03:25 PM
VintageMusclecar's Avatar
Dave;
As long as the bores measure out good and the pistons are still in good shape, you can swap out the rotator from the `65 block into the `72 unit. That alleviates the rear cam bearing snafu as well as the need to run a canister oil filter or one of those wonky adapters.
Eric
Old 07-13-2017, 03:38 PM
Sean Sean is offline
I would sonic test it.
Old 07-14-2017, 04:44 AM
markjohnson's Avatar
My 1965 Z-16 Chevelle motor had been bored out to a 4.25 (plus another .060 for a total bore size of 4.310 and 440 CID). I've heard this was only possible on the thick-walled, 1965 4-bolt main blocks.
