Old 06-19-2017, 08:11 AM
X66 714's Avatar
X66 714 X66 714 is online now
Default 1969 Camaro Door panel window wiper
I'm having Al Knoch redo my deluxe door panels for my 69 Camaro. My window wipers are too old & not pliable enough to reuse. The replacements I've seen, the "V" cross section is not a true "V". More like a check mark.
Is there a correct wiper for the deluxe door panel on the market?
Thank you, Joe
Old 06-19-2017, 08:54 AM
Lee Stewart's Avatar
This help?
http://www.heartbeatcitycamaro.com/s...-wiper-blades/
Old 06-19-2017, 11:49 AM
ZLP955's Avatar
ZLP955 ZLP955 is offline
Lee he's asking about the inner fuzzies that attach to the top of the door panels.
Joe, sorry can't offer anything - haven't researched that part of my in-progress restoration yet.
Tim in NSW, Australia
The Following User Says Thank You to ZLP955 For This Useful Post:
bigsixman (06-20-2017)
Old 06-19-2017, 12:23 PM
OOPS!
These are what he means right?
https://www.camarocentral.com/1968_1..._p/7729998.htm
Old 06-19-2017, 12:44 PM
cook_dw's Avatar
cook_dw cook_dw is offline
Those are outers.. Hes asking about the piece that is attached to the door panel itself.
Old 06-19-2017, 12:46 PM
Missed again. He needs the INNER fuzzies, not the outer fuzzies.
Outers attach to the door frame.
Inners attach to the door panel.
Edit: Darrell beat me to it.
Old 06-19-2017, 03:07 PM
X66 714's Avatar
What sucks is I have a NOS set. Had them for years. Took them out of their sealed packages & they're hard as a rock. Elliot Knoch said mine would break if he tried to re-staple the originals.....Joe
Old 06-20-2017, 12:22 AM
What about just replacing the "fuzzy" material?
http://www.heartbeatcitycamaro.com/s...uzzy-Material/
Old 06-20-2017, 01:21 AM
Boy Lee, not trying to be an arse, but this isn't your day. The part he needs runs the full lenght of the window attached to the door panel. Normally referred to as the inner fuzzy. Little different texture than the outer fuzzie, which also runs the full length of the window but attaches to the door frame.
Pictured here: http://www.ebay.com/itm/68-69-Camaro...9ZMIDO&vxp=mtr
As noted above, even an NOS set may have become very hard if not stored in a climate controlled environment.
The door adjuster ALSO has a fuzzy piece on it. That fuzzy piece is in the link you posted There are (I think) two to each front window. They attach to the door and allow adjustment of the angle of the window. That fuzzy pieces is only about an inch and a half on each adjuster.
Pictured here:
http://www.ebay.com/itm/1968-1969-CA...ZXVypY&vxp=mtr
