Old 06-15-2017, 01:26 PM
day2killa day2killa is offline
Default lakewood roll bar back seat?
i just installed a lakewood roll bar in my 1969 Chevelle and the back seat has no chance to slide in, what do I do cut up an original seat?
Old 03-19-2019, 10:05 PM
Outlaw68Nova Outlaw68Nova is offline
Any pictures ?
Old 03-20-2019, 03:19 AM
NorCam's Avatar
NorCam NorCam is offline
I just installed one in a 70 Nova and it was tricky getting the seats back in after...but a little twisting and maneuvering and it eventually dropped in. I got the seat back to drop down where it then contacted the bar and I marked it with some white chalk around the rear leg of the roll bar. I then slid the seat bottom back in and it actually dropped into the lower locks without needing any cuts at all. I pulled them back out and cut the lower front cross wire along the front of the seat back and made a couple incisions into the seat vinyl to give it some relief and dropped it back it. It fit around the bar and did so without any stress on the seat or fabric and fits great around the bar.
Not sure how much different a Chevelle is from a Nova but found this very doable. Just had to be patient while twisting the seats back in from the passenger side. The seat back goes in right side up and left side down low and needs to be twisted while the face slides over the bar from the passenger side. Be sure to watch the lower tab doesn't tear into your headliner and that the left side doesn't scratch the lower door jamb as it slides in from the jamb. Hope this helps you out.
Outlaw68Nova (03-21-2019)
Old 03-21-2019, 01:13 AM
What do the Lakewood Nova floor mounts look like? Thank
Old 03-21-2019, 11:52 AM
NorCam's Avatar
Not sure but think they are similar to Camaro. The bar I installed was for Camaro and the feet were a close match along the rear floor and rockers. Slight mods were made and we had to bend the rear floor mount in a 20 ton press to add a kick to it. Also had to extend to the rear tube by 3/4" to fit right at the back seat.
Old 03-22-2019, 05:29 PM
DW31S's Avatar
DW31S DW31S is offline
I installed one in my Camaro. Like Graeme says, with a little tweaking, I got my back seat back in. I had to roll down rear 1/4 windows and do some bending and twisting (the seat, not me....well, me a little) but I did get the seat back and bottom locked in their original places/positions. My bar was a Camaro unit, with Camaro mounting plates. I'm told the bars are all quite similar with differences in the mounting provisions. I'd think that if you have all pieces correct for your Chevelle, the rear seat should fit after installing the rollbar.
Old 03-24-2019, 01:03 PM
MosportGreen66's Avatar
Grady and Mike had a great solution for their COPO Camaro restoration... let me see if I can find pics.
