Old 06-09-2017, 04:03 AM
turbojet427 turbojet427 is offline
Yenko Advertising Member
Default 68 Camaro L78 parts
Selling some of the parts that came from a parted out 68 L78 M22 Camaro with 31K miles and a 5E build date. Some of these parts might also be for a Z/28. All parts listed are assembly line off the car.
BB engine mounts in good useable shape $125
1111170 Distributor dated 8E14 with original Delco cap and vacuum advance $1,200
5 blade clutch fan with big W and correct tight clutch dated 5/10/68 $700
BB oil pan $300
Timing Chain cover with correct tab $150
621 Bellhousing $150
M22 rockcrusher dated P8E15 with 68 Camaro VIN and the original Muncie Shifter $2,000
11" flywheel dated 8E18 $150
BB water pump dated E 11 8 $150
Deep Groove Double Water Pump and Crank Pulleys $650 pair
Instrument cluster with 31,xxx miles and 6-8K redline tic toc tach. $750
Alternator brackets and a smog bracket. $350 for all 3.
L78 396 short block. Standard Bore, CE074450 dated J89 casting #854. Block looks real good and very clean. 6223 crank, fordged rods, original pistons, oil pump, cam, lifters. $2,750
Please PM with questions/offers or call/text me 814-244-7108. All parts are as is and buyer pays shipping.
Attachments - The Supercar Registry thumbnail_20170607_203245_resized.jpg thumbnail_20170607_202658_resized.jpg thumbnail_20170607_202524_resized.jpg thumbnail_20170607_202422_resized.jpg
