Old 06-02-2017, 04:51 AM
Default Ball Joints : Bolting ????
I'm using Bolt In Upper Ball Joints in my driver 73 Camaro R/S project.
I'm thinking to use 1/4-20x1" Button Head Allen Bolts for a more
"rivet like" appearance. Not sure what kind of nut (grade 8 ??) my
fastener store can offer me.
Ball Joints made off shore did not come with (metric ??) zirc fitting !!!!
Any problem with this idea ???
Chuck Sharin
[email protected]
69 Camaro COPO "recreation"
Old 06-02-2017, 12:36 PM
Default Rivets..
After you install the allen head bolts use a little 'all-metal' filler to hide the hex shaped hole..smooth it over...finish with some cast steel paint and the average Joe won't know the difference.
Old 06-02-2017, 01:39 PM
earntaz earntaz is offline
I would use grade 8 fasteners (bolt/nut) ... TAZ
Old 06-02-2017, 02:04 PM
RPOLS3's Avatar
RPOLS3 RPOLS3 is offline
Most of the Corvette restoration parts houses sell the threaded "rivet" for this application
http://www.zip-corvette.com/68-82-c3...t-nut-set.html
Jake Dykstra
Dykstra Motorsports
Old 06-02-2017, 02:31 PM
Default rivets/bolts..
Do those Corvette fasteners have an 'allen head' ...can't tell from the photo.
-wilma
Old 06-02-2017, 02:40 PM
RPOLS3's Avatar
-wilma
Typically they do not and from the top look just like the rivets - so no need to fill anything in. They are sold from other vendors as well.
Ground up sells this kit which the rivets look a little different than the Corvette guys.
http://www.ss396.com/chevelle/DRVT-33.html
Jake Dykstra
Dykstra Motorsports
Old 06-02-2017, 03:24 PM
Default rivet/bolts..
What holds the bolt in place as the nut is tightened??
Old 06-02-2017, 03:57 PM
RPOLS3's Avatar
I'd be curious what others have done on this as well. Looks like the torque spec is about 60# from a quick google search.
Jake Dykstra
Dykstra Motorsports
Old 06-02-2017, 04:01 PM
Maybe it is a tight fit, but I'm not sure how that would hold up to 60 lbs. of torque??
I suppose you could hold the rivet w/vise grip, but that mark them up and ruin the look. There must be a trick..
-wilma
Old 06-02-2017, 04:17 PM
Wink rivets/bolts..
I called both places and neither of the sales reps. knew the answer...the Corvette place sent me to their tech line...just got a voice mail...Ground Up guy placed me on hold and asked someone...he tells me the bolts have a knurl on them that secures them in place to facilitate tightening the nut...he also said they carry the actual rivets if you are going that route.
***the knurls don't seem to be shown in the website photos for the item
Tom from the Tech Dept.
The Following User Says Thank You to WILMASBOYL78 For This Useful Post:
Spike (06-02-2017)
