Old 05-17-2017, 02:46 PM
Parts4race351 Parts4race351 is offline
Default 427 396 402 blocks and misc rare parts selling all one shot lowered price
For sale is a ton of rare 60's and 70's chevy muscle car parts
Here is a list of what I have
1- 3963512.... ce. I 18 9....4 bolt 427 $4500
2- 3955270 no pad numbers standard deck height checked with etch
H 23 8 2 bolt 427 $4500
3- 3969854.. t10070ctx.. j 20 8 2 bolt 402 $500
4-3916321... ti024ir... i 18 7 4bolt 427 68 corvette vin $5000
5-3999290.. ce .... c 15 73..... 2 bolt 402 $500
6- 3869942 no stamp also etched and no numbers found..
J 18 6 4 bolt 427.. $5500
7- 3855961.. ef ... e 13 6... 2bolt 396 $3500
8- 3855961.. to33ie.. c 15 6.. 2 bolt 396 425hp $4500
9- 3916321.. to9i3ij.. i 2 7... 2 bolt 427 $5000
Also 7115 crankshaft needs to be cut. $500
Almost new set of original l88 pistons $450
N.o.s set of l88 pistons with nos rings and wrist pins. Rare!!
$2100
492 small block heads $300
Nos in original box NMW torque lift ladder traction bars for gm intermediate coil spring cars chevelle ect...
N.o.s 61 corvette dash housing $1100
61 corvette ram horn exhaust manifolds $300 pr
Zl1 fuel pump $350
69 copo 427 camaro fuel pump $400
Crate full of small and big block crank pulleys some n.o.s corvette..
2 muncie cases $450 each
1 muncie tranny (apart) $800
3 misc big and small block point distrbutors
1 big block rt side exhaust manifold unknown date as shield is still on.. $200
1969 camaro small block fan shroud original $150
Nos set of 8 r45xls Ac delco spark plugs $150 set
Ac delco nos 4000 and 5001 guide headlamp bulbs 1 of each $75 each
Nos gm guide plates 2 sets $100 set
Nos gm head bolts long and short 2 sets
5 alternators all mid 60's need rebuilt
1 starter 61 date and 1 starter housing I forget the date
Original corvette caliper cores 3 of them
Misc n.o.s ac delco fuel pumps.. about 5
Big block clutch fans
Small block clutch fans
Misc components from copo smog system
1970 camaro ss steering column and wheel with ss horn ring $250
Crate of small and big block engine brackets.
Original big block camaro harrison radiator core good tanks
$350
1969 small block 4 barrel intake with original quadrajet.
$200
Delco remy raised letter distributor caps 2 used 1 n.o.s
100 each used and 150 for nos
1966 and a 1967 big block water pump $175 each
12 bolt 4 series carrier
Corvette 3 and 4 series carriers 1 of each
Im sure there is more
Looking to sell as a complete lot
25,000 firm
