Old 05-14-2017, 02:43 AM
Tim_Rivette Tim_Rivette is offline
Default 1969 Camaro SS396 Cortez Silver
1969 Chevy camaro SS 396
Numbers Matching 1969 Camaro with 396 350HP. Recent restoration.
1 of 2018 built with a 396 350 HP automatic A/C car
This is a real numbers matching car not a clone... A/C blows ice cold air with everything in the AC system new . Compressor, hoses, condenser, evaporator core, POA valve sent to original air product to be rebuilt and calibrated for 134A. Interior is all new upholstery from carpet to headliner. Paint is fresh in the correct cortez silver with a new vinyl top and trim. tilt column.... grill and grill trim is new GM and headlights converted to electric from retro electro for a no problem operation. This car drives like a dream with no issues. Engine has been rebuilt and it still has the correct points distributer and coil Transmission is not the numbers matching trans but it is the correct turbo 400. Rear is the correct BL coded 3.08 ratio 12 bolt posi rear end.
Lots of more info available if you need it
47,500.00
Thanks Tim 4097812619
Attachments - The Supercar Registry IMG_2519.JPG IMG_2514.jpg IMG_2495.jpg IMG_2471.JPG
