Old 04-13-2017, 01:28 AM
69VN's Avatar
69VN 69VN is offline
Default Ignition Coil Brackets/Bolts
Here are two original ignition coil brackets...Both brackets have been
media blasted and will need re-plating and are in very good condition.
The first bracket does not come with the mounting bolts but does have
the adjusting screw and condenser clamp/screw. The second bracket does
come with original mounting bolts, adjusting screw and the condenser mounting
screw (minus the clamp). Top 5 photos are the 1st. bracket, bottom 5 photos
are that of the 2nd. bracket....$55 plus shipping (to lower 48 states) for 1st.
bracket and $75 plus shipping (to lower 48 states)for the 2nd. bracket. Any
question feel free to inbox me.
Sal
