Old 03-31-2017, 09:27 PM
ALLZS ALLZS is offline
Default Hurst linkage clips
On 1969 s/b hurst linkage what is correct to hold linkage rod to shifter & side cover arm to the rod
Attachments - The Supercar Registry wave washer.jpg reverse rod hair pin.jpg lever rod with wave washer cotter pin.jpg DSCN5864.jpg
Old 04-01-2017, 03:02 AM
tunes's Avatar
tunes tunes is offline
That would be the clip on the left.
Robert
_______________
1969 Chevelle SS396 L78 M21 4.10
2023 Stingray Coupe Z51
Old 04-01-2017, 03:06 PM
x77-69z28's Avatar
Absolutely
Old 04-01-2017, 06:13 PM
Ok thanks just wondering way the factory asembly manuel shows cotter pins ?
Old 04-01-2017, 07:16 PM
fiveforty fiveforty is offline
I was gonna reply but was not sure, did some have cotter pins on the shifter.
Old 04-01-2017, 07:35 PM
earntaz earntaz is offline
I know for a fact that aftermarket CompPlus Hurst shifters (example) came with the clips shown on the left -- they did not use cotter pins. The clips can be a pain in the south-end to install and sometimes go a-flyin' -- that's why there are Hurst shifters out there with cotter pins ... and they rattle like an SOB ... TAZ
Old 04-01-2017, 08:29 PM
Steve Shauger's Avatar
Administrator
Original were cotter pin and wave washer. I'm not referring to after market Hurst.
www.vintagecertification.com
Old 04-01-2017, 08:32 PM
Must be before the late 60s ... every aftermarket Hurst I have seen/installed had the clips ... TAZ
Old 04-01-2017, 09:04 PM
Thats correct i am working with a factory installed hurst 4 speed shifter not a after market unit
Old 04-02-2017, 12:35 PM
Administrator
The factory shifters and trans levers also incorporated rubber grommets at the rod connections to minimize noise. Aftermarket shifters used bushings and clips.
